Samsung ST1000LM024 hangs with continuous terminal output
Posted: 28.03.17, 16:47
I have a couple drives in the lab both doing this continuously in the terminal when I try to read using DE.
During this output the drive stays BSY. It will come ready after a power cycle and read a few sectors but then just goes BSY again.
Below is the continuous terminal output while the drive is in BSY state.
I know that a heads 1,2 are bad out of 0,1,2,3. Perhaps its getting stuck in BSY when reading a with a bad head.
Both get full id and come ready easily.
Any suggestions other than the obvious swap?
[GL][TP:001B49B9D0][E:1140]
[GL][ADD:01B49B9D0][C:0005][E:1140]
[GL][RS:05 01B49B9D0 9097A000]
