List of PCB USB --> to SATA PCB
Posted: 03.11.16, 10:40
by Marek
USB ---> SATA
USB HN-M500XBB/VP4 PCB M8_329_REV.02 ROO ---> HN-M500MBB/LCP (ST500LM012) PCB: M8_REV.03 ROO (FROM USB WRITE ROM TO SATA)
USB HM641JZ/VPK PCB MS3M_AS_REV.02 R00 G2 REV.2 ---> HM641JI (ST640LM000 PCB: S3M_REV.02 R00 s3 rev.2 (FROM USB WRITE ROM TO SATA)
USB HN-M101ABB/EX2 (ST1000LM025) PCB M8U_REV07 ROO 1S REV 7 ---> HN-M101MBB/AS2 (ST1000LM024) PCB: M8_REV.07 ROO 1V REV 7 (FROM USB WRITE ROM TO SATA)
If You have other example - Please Write it :)
Re: List of PCB USB --> to SATA PCB
Posted: 03.11.16, 17:37
You can find some others on this thread: https://www.data-medics.com/forum/samsu ... html#p5745
Posted: 10.03.18, 17:25
by antonvn
May I add my question to this post as it is also about USB to SATA PCB?
I have a Samsung HM502JX, PCB BF41-00282A 00, M7S-S_LINE REV .01 - which is a compatible SATA PCB? I have had a look at converting to SATA, but those pads are way too tiny for me.
Posted: 14.03.18, 12:39
by vijayan
Dear Antonvn
This Case Sovled ? PCB BF41-00282A 00, SATA PCB NUMBER ?
antonvn wrote:Source of the post May I add my question to this post as it is also about USB to SATA PCB?
Posted: 14.03.18, 17:17
Just a guess here, but I think the necessary board might be: BF41-00249B
I've never tried it, but the main IC and motor controller seems to match.
Please do update whether or not that's the correct board when you get this case solved. I'd like to update my list mentioned above.
Posted: 31.05.18, 15:09
by northwind
DataMedics wrote:Source of the post Just a guess here, but I think the necessary board might be: BF41-00249B
Sorry to bring up an old thread, but I've just confirmed this.
BF41-00282A <-->BF41-00249B COMPATIBLE.
Posted: 31.05.18, 22:40
northwind wrote:Source of the post
Cool! Thanks for confirming. Added it to my list.
Posted: 29.06.18, 19:04
by vijayan
how rom file backup ? io ic rom inside How to ex rom ?
Posted: 02.07.18, 19:34
You can try using boot rom code to see if the PCB will respond and allow you to read it over the com port. Otherwise you have to rebuild the ROM from the service area. Drives w/o an external ROM always have a backup copy in SA.
Edit: oops, posted this as a response to the wrong thread. that's what I get for browsing in multiple tabs at once... ignore this comment.
Posted: 25.02.20, 13:38
by igen
BF41-00325A ---> BF41-00320A
Posted: 01.02.24, 09:18
by gameboybin
Sorry for bringing this up. Got same case
Can anyone tell me where to solder the sata points???
