Hard to find parts ST1000LM025
Posted: 26.05.16, 15:05
by hddr49
Hi there,
I have a case with a ST1000LM025, I failed to find a donnor.
P/N is HN-M101ABB/EX3
Do you ever try to head swap with a ST1000LM024, with P/N are like HN-M101MBB/LC2 ?
Thanks.
Re: Hard to find parts ST1000LM025
Posted: 31.05.16, 22:08
You can usually disregard the part after the / (e.g. /EX3). Just find another HN-101ABB with similar date and same country. Not sure about crossing models like that, I've never tried it. However if the date is close and the headmap is the same, it may well work.
Posted: 02.06.16, 10:28
by hddr49
I'll give a try and let you know.
Posted: 09.06.16, 11:00
You need to make a match against the middle set of 4 digit codes at the P/N, or alternatively place patient pcb on donor and if donor spins then heads are likely compatible.
Also, ST1000LM024 and HN-M101MBB are the same drive. This would work.
Posted: 03.04.17, 15:49
by Wanderson
Hello I have a case I need to turn a ST1000LM025 EX3 in sata
I have a sata card in which works for ST1000LM025 but this board SATA not working this ST1000LM025 EX3
can help me what pcb sata is compatible for ST1000LM025 EX3?
Posted: 04.04.17, 15:48
Wanderson wrote:Source of the post Hello I have a case I need to turn a ST1000LM025 EX3 in sata
I Could Not Understand ,Can You Show Your Patient Board Is That USB/SATA You Are Not Clear Or i Failed To Understand
