List of PCB USB --> to SATA PCB
Moderator: Garry_TS
Marek
Postby Marek » 03.11.16, 10:40
USB ---> SATA
USB HN-M500XBB/VP4 PCB M8_329_REV.02 ROO ---> HN-M500MBB/LCP (ST500LM012) PCB: M8_REV.03 ROO (FROM USB WRITE ROM TO SATA)
USB HM641JZ/VPK PCB MS3M_AS_REV.02 R00 G2 REV.2 ---> HM641JI (ST640LM000 PCB: S3M_REV.02 R00 s3 rev.2 (FROM USB WRITE ROM TO SATA)
USB HN-M101ABB/EX2 (ST1000LM025) PCB M8U_REV07 ROO 1S REV 7 ---> HN-M101MBB/AS2 (ST1000LM024) PCB: M8_REV.07 ROO 1V REV 7 (FROM USB WRITE ROM TO SATA)
If You have other example - Please Write it :)
Re: List of PCB USB --> to SATA PCB
Postby DataMedics » 03.11.16, 17:37
You can find some others on this thread: https://www.data-medics.com/forum/samsu ... html#p5745
antonvn
Postby antonvn » 10.03.18, 17:25
May I add my question to this post as it is also about USB to SATA PCB?
I have a Samsung HM502JX, PCB BF41-00282A 00, M7S-S_LINE REV .01 - which is a compatible SATA PCB? I have had a look at converting to SATA, but those pads are way too tiny for me.
vijayan
Postby vijayan » 14.03.18, 12:39
Dear Antonvn
This Case Sovled ? PCB BF41-00282A 00, SATA PCB NUMBER ?
antonvn wrote:Source of the post May I add my question to this post as it is also about USB to SATA PCB?
Best regards,
vijayan MBA
RDR DATA RECOVERY
call 7092114411/22
sky:raminfotech.vijayan
whatup:9841983643 / 46
Postby DataMedics » 14.03.18, 17:17
Just a guess here, but I think the necessary board might be: BF41-00249B
I've never tried it, but the main IC and motor controller seems to match.
Please do update whether or not that's the correct board when you get this case solved. I'd like to update my list mentioned above.
northwind
Postby northwind » 31.05.18, 15:09
DataMedics wrote:Source of the post Just a guess here, but I think the necessary board might be: BF41-00249B
Sorry to bring up an old thread, but I've just confirmed this.
BF41-00282A <-->BF41-00249B COMPATIBLE.
Postby DataMedics » 31.05.18, 22:40
northwind wrote:Source of the post
Cool! Thanks for confirming. Added it to my list.
vijayan
Postby vijayan » 29.06.18, 19:04
how rom file backup ? io ic rom inside How to ex rom ?
Best regards,
vijayan MBA
RDR DATA RECOVERY
call 7092114411/22
Postby DataMedics » 02.07.18, 19:34
You can try using boot rom code to see if the PCB will respond and allow you to read it over the com port. Otherwise you have to rebuild the ROM from the service area. Drives w/o an external ROM always have a backup copy in SA.
Edit: oops, posted this as a response to the wrong thread. that's what I get for browsing in multiple tabs at once... ignore this comment.
igen
Postby igen » 25.02.20, 13:38
BF41-00325A ---> BF41-00320A
Marcus Tullius Cicero
Postby gameboybin » 01.02.24, 09:18
Sorry for bringing this up. Got same case
Can anyone tell me where to solder the sata points???
Return to “Samsung USB”
