wd800jd-75m8a3
crim-dei
wd800jd-75m8a3
Postby crim-dei » 26.11.15, 11:59
How can i access to service area? SA SPT number?
Re: wd800jd-75m8a3
Postby AJ2008 » 27.11.15, 10:57
Access to SA fully depends on the problem with the drive. If drive is operational, it can determine its own SPT. If heads are bad, entering SPT will make no difference to access.
What symptoms does it show?
Return to “WD OLD”
