Doomer wrote:Source of the post Takanashi_Hina wrote:Source of the post There are standard ATA command to disable retries. Command "EF" with 33 ate error/feature register. Don't have a clue if WD for some reason will reject the command but i can try.
I think you confusing "Read Look Ahead" with "Read Retries Count"
Theoretically there could be a "Read Retries Count" in features part in module 02 but I'm not sure, some digging required.
Not confusing them both :
STANDARD ATA :
SET - Disable Retries=33 00 00 00 00 00 EF 00 00
SET - Disable Read Look-Ahead=55 00 00 00 00 00 EF 00 00
Standard ATA to disable retries don't work on my WD test drives. Some "Chinese" piece of software that i have does have a VSC to disable "hidden" retries. Don't have a clue about what it does as i did never tested it.
