WD20EZRZ-00Z5HB0
Posted: 07.10.18, 18:26
by rms620
I have WDC WD20EZRZ-00Z5HB0 2TB.
The WDC Marvel Util recognizes this HDD with Serial, Model and correct capacity.
Techno mode key
SA SPT.................................. : 1740
Modules directory address............... : 330 212
ROM Modules:
ROM version............................. : 15.ABC
ROM F/W version......................... : 001500AB
Overlay F/W version..................... : 15.ACC
Servo F/W version....................... : 05.67
Heads map............................... : 0,1,4,5
Service area:
But gives ABR error on reading any sector shows me "Techno OFF error Device Error Detected: "Unknown error code: 4344".
I tested Heads and all are Health.
All modules in both copy 0 and copy 1 are ok.
I even changed PCB for sure but I have same problem.
I did Translator Regeneration ( use P-list Only) but i have same problem and i haven't access to user data area.
Please help me ..
Thanks a lot
Re: WD20EZRZ-00Z5HB0
Posted: 09.10.18, 11:08
by rms620
thanks for your reply. :x :x :x :x
I solved it myself :wave: :wave: :wave:
Posted: 17.11.20, 11:34
by aryadiba
I have same problem. Could you notice how did you solved this problem? tnx
Posted: 19.11.20, 14:20
by Maxim_TS
aryadiba, the issue may be in Slow Responding. Also need to try RAM head map changing for system heads http://blog.acelab.eu.com/ram-head-map- ... -case.html
