Fblite WD10JPVX - ID is not recognized
AdasRip
Postby AdasRip » 05.10.18, 16:14
I have patient: WD10JPVX-22JC3T0.
The heads seem to be working. HDD becomes ready but the ID is not detected.
I get a such reading in utility (normal mode). How to bite it?
Code: Select all
Techno mode key
ROM version............................. : 16.0TG
ROM generation.......................... : 16.0TG
Link table version...................... : N0.18.
Consolidated ROM version................ : 0016000T
ROM Modules:
Modules directory address............... : 161 929
ROM Firmware version.................... : 0016000T
Service area:
Configuration reading................... : No SA copy avalabled
Re: Fblite WD10JPVX - ID is not recognized
Postby AJ2008 » 05.10.18, 16:21
AdasRip wrote:Source of the post Permanent overlay....................... : Not loaded
Try to load Loader and check SA structure looks ok
GuideRecovery
Postby GuideRecovery » 06.10.18, 12:33
here is what you can do:
1. Block SA Access in ROM
2. Start Utility in Kernel Mode
3. Load Ldr+Dir from SA
4. Start utility in normal mode
see if you can access modules now, if yes check SA structure.
Wasim Zafar
https://mindmergepk.com
AdasRip
Postby AdasRip » 16.10.18, 15:55
Thank you for your help.
I've loaded module 11 from here and it works:
http://files.hddguru.com/download/PC-30 ... 3C2588.rar
