ROM/LDR for WD5000BMVW-11AJGS3
Posted: 21.09.18, 14:51
by storeC Padua
I am looking for ROM/LDR combination that I can try to attempt to gain access to the SA on this case I have. Any help is appreciated!
Drive model is WD5000BMVW-11AJGS3
firmware is 0016001C
family FBLite 2.5"
I hope someone can share it
Re: ROM/LDR for WD5000BMVW-11AJGS3
Posted: 21.09.18, 14:57
You will need original ROM and a LDR of corresponding FW revision. Using a donor ROM will not allow access to SA or data
Posted: 21.09.18, 16:22
by storeC Padua
Thank you for your answer.
I have this situation
rec 34812.jpg (5.05 KiB) Viewed 3117 times
Posted: 21.09.18, 16:24
Upload LDR with a corresponding revision that matches your ROM, and then check how it behaves
