Wd Fblite drive becomes busy after unblocking sa
Posted: 16.08.18, 07:53
by jamesrajesh007
WD10JMVW USB DRIVE solved slow responding problem and got folder structures and head no.0 was quite slow reading i powered off the drive and re powered on to start cloning, drive again stays busy so blocked sa upload ldr and tried to unblock sa drive becomes busy again all the modules are reading fine except 21 (smart) on head 0 can any one help
Re: Wd Fblite drive becomes busy after unblocking sa
Posted: 16.08.18, 08:49
after upload LDR step run head map edit and set to 1123 to rule out issues with H0 - after soft reset if all is ok it should come online, but remember to reset to 0123 before trying to read data under H0 again
