WD Platter Replacement (Alignment Issue)
Posted: 09.07.18, 16:04
by shahi
Do you have good success rate about platter replacement of WD 3.5"?
Considering Alignment issue? (motor balance issue)?
Its a 1 platter HDD I am dealing.
Re: WD Platter Replacement (Alignment Issue)
Posted: 09.07.18, 16:48
It depends on model of WD - older 3.5" (Pre-ROYL) I would say there is problem with it. modern families, I would say not so much
Posted: 09.07.18, 17:27
by Amarbir[CDR-Labs]
shahi wrote:Source of the post Do you have good success rate about platter replacement of WD 3.5"?
do you have a active case can you give more details please
Posted: 09.07.18, 18:04
by shahi
Hi Amar,
What more info do you need?
Hi Aj2008,
Its WD10EZEX-08M2NA0
Posted: 10.07.18, 06:41
by northwind
You shouldn't have any problems with it.
Posted: 12.08.18, 09:15
Shahi ,
This Motor Balance Issue is a Hoax Created By DFL On their Website And Forums .If you tighten the platter in a cross section with right tongue there is no issue ,I have done several multiplayer drives too
