WD 750GB Black
Posted: 06.06.18, 11:09
by Delta1
I am new in PC3000 blog :?
I have WD 750GB 2.5" HDD (WD7500BPKT), :x
The HDD spin normal and no noise, the status registers are also normal. :thumbup:
I just need the user data, kindly guide me.. :idea:
A few screenshots are attached for reference :?:
SA Logs.png (23.04 KiB) Viewed 5238 times
HDD SA Geometry parameter.png (24.81 KiB) Viewed 5238 times
Auto Detect.png (29.84 KiB) Viewed 5238 times
Re: WD 750GB Black
Posted: 06.06.18, 11:43
by huangmiaofang
Load this LDR
11_0009002S.zip
(189.76 KiB) Downloaded 507 times
Re: WD 750GB Black
Posted: 07.06.18, 09:41
by northwind
Why are regions spared and 02 blocked?
Were you just pressing buttons around?
Unblock 02 and revert SA regions to normal and then post again drive's behavior.
Re: WD 750GB Black
Posted: 07.06.18, 11:03
by Maxim_TS
northwind, maybe Delta1 got the drive in current state :)
Delta1, heads are good, the Dir is readable by ID at least.
Just block SA access, go to Work with RAM, load Dir and loader into RAM, and tell us what's happening.
Re: WD 750GB Black
Posted: 12.06.18, 10:06
by Delta1
Thanks brothers
I have follow the steps as:-
Block SA access, go to Work with RAM, load Dir and loader into RAM
But have no success
Here are few more screenshots for your reference.. :shockable:
Kindly Guide me if is there any other way to copy the user data :umnik:
Re: WD 750GB Black
Posted: 12.06.18, 18:51
by Maxim_TS
Delta1, please submit a ticket for me at http://ts.acelab.eu.com/ with teamviewer.
