WDC WD10SDZW-11UMGS0 WHICH FAMILY
Posted: 16.05.18, 15:20
by CS DATA RECOVERY
Hi ,
i have a WD My Passport 2.5" USB Drive i have converted usb to sata drive DRD DSC which family i need to select? auto not worked .
Pavan.
- 5.JPG (16.17 KiB) Viewed 28362 times
Re: WDC WD10SDZW-11UMGS0 WHICH FAMILY
Posted: 16.05.18, 23:26
If I had to wager a guess, I'd say it's Palmer family, which is a new one. You can probably do most things you need to do using another recent family like PebbleB though.
Posted: 17.05.18, 07:09
by CS DATA RECOVERY
Thanks Data Medics
i have isolate pcb tried PebbleB then i got SED drive locked may be PC3000 not support this model & family .
Pavan
- 10.JPG (32.15 KiB) Viewed 28330 times
Posted: 17.05.18, 18:11
Did you attempt the ROM preparation? Perhaps it's the same SED scheme.
Posted: 22.05.18, 08:43
by Maxim_TS
CS DATA RECOVERY wrote:Source of the post then i got SED drive locked may be PC3000 not support
you are right, such drives are SED locked in ROM and have a lot of another different issues. They are not supported in PC-3000 for now.
Posted: 12.06.18, 20:40
by Doomer
It's a Palmer drive (other Palmer drives Y0TS, Z10T, UMGS, EW0T)
Palmer drives are locked differently comparing to previous SED families.
Palmer drives are not supported by PC3K(including unlocking procedure), but you can outsource such drives to people who can do them.
Posted: 28.09.18, 08:57
by vijayan
Model : WDC WD10SDZW-11UMGS0
Serial : WD-WXH1A67DN0KV
Firmware : 01.01A01
Capacity : 1 000 GB (1 953 459 632)
SA HDD has unknown capacity. SA CHS access may operates wrongly
Cyl Count............................... : 512
SA SPT.................................. : 1944
Read ROM................................ : HDDs ROM reading error Data request error Device Error Detected: "SED DRIVE LOCKED"
Service area:
SA dir reading (ID)..................... : SED DRIVE LOCKED
SA dir reading (ABA/CHS)................ : Dir reading error ABA 0(1) reading error Device Error Detected: "SED DRIVE LOCKED"
Configuration reading................... : Module ID 02 reading error Data request error Device Error Detected: "SED DRIVE LOCKED"
Reading modules
Into folder............................. : <HDD Profile>\Data\Modules\
HOW TO FIX PROBLEM
1HOW TO SA COPY
2.HEAD MAP
- WDC WD10SDZW-11UMGS0.JPG (6.58 KiB) Viewed 27768 times
Posted: 01.10.18, 10:34
by Maxim_TS
vijayan, these drives are still unsupported in PC-3000. It's not possible neither to build head map nor to get SA access now. ACE is working on it now, hopefully they will find the solution.
Posted: 15.10.18, 09:24
by cuumaytinh
is it support ?
Posted: 16.10.18, 16:23
by Maxim_TS
it's PC-3000 forum where all PC-3000 users can discuss different issues related to data recovery. If you want to contact Technical Support department, please follow
https://ts.acelab.eu.com
Posted: 04.11.18, 06:42
Hi Maxim,
How Are You Today ,When Do You Think Will Pebblep , Spyplass ,Palmer Etc Be Supported For Proper Working In PC 3000
Posted: 10.01.19, 11:19
by cuumaytinh
for V6.5 pc3000 is supported Pebblep , Spyplass but Palmer is not yet.
Posted: 12.02.19, 05:23
by shahi
Working with a Palmer.
Can READ SA. But cant HEAD MAP
TRIED TO IMAGE, MOST DATA AREA SAYS UNREADABLE, REST AREA READS SMOOTH.
Whats your experienc?
Posted: 14.02.19, 12:18
by Maxim_TS
Head map editing in RAM and head map building in Data Extractor are not possible for these new drives due to new LBA-CHS conversion.
ACELab developers are woring on it.
Posted: 19.11.19, 13:25
by vijayan
PASSWORD RECOVERY POSSIBLES ?
- WhatsApp Image 2019-11-19 at 7.01.40 PM.jpeg (165.15 KiB) Viewed 21825 times
