WD30EZRZ-00Z5HB0 Slow Responding & SED Locked?
Posted: 12.02.18, 22:14
by murphman
I have a 3.5" WD30EZRZ-00Z5HB0; the drive is behaving like it has a Slow Responding Problem. If I leave the drive on and just wait auto detect it gives error "SED DRIVE LOCKED"
I tried putting jumpers in to start in kernal that doesnt work either.
The drive never gets recognized by utility in kernel or otherwise therefore I cannot block access to SA or to any module for that matter.
Has anyone dealt with this kind of problem, I am at a loss here.
Re: WD30EZRZ-00Z5HB0 Slow Responding & SED Locked?
Posted: 13.02.18, 00:29
by Blizzard
You should be able to isolate the heads and then block SA access in ROM. Here is a good tutorial for WD SED on Ace Blog.
Posted: 13.02.18, 09:53
Posted: 13.02.18, 17:13
by Maxim_TS
murphman wrote:Source of the post tried putting jumpers in to start in kernal that doesnt work either.
Connect the PCB with jumpers, and wait until all LED registers in the bottom of PC-3000 are off. Then follow the manual viewtopic.php?p=34404#p34404
Posted: 13.02.18, 17:36
by murphman
Thank you for the responses. I read both articles actually, problem is this is a 3.5" drive not a 2.5" so head isolation wont work. I tried putting in the 3 jumpers (to enable kernal in 3.5") but doesnt work either. I get "SCT DATA XFER CMD ISSUED WO SCT KEYSECTOR CMD" error.
Thanks Maxim, when I put the jumpers in the LED does indeed turn off; what manual do I follow afterwards? The link viewtopic.php?p=34404#p34404 is for this post!?
Posted: 13.02.18, 17:38
murphman wrote:Source of the post Thank you for the responses. I read both articles actually, problem is this is a 3.5" drive not a 2.5" so head isolation wont work. I tried putting in the 3 jumpers (to enable kernal in 3.5") but doesnt work either. I get "SCT DATA XFER CMD ISSUED WO SCT KEYSECTOR CMD" error.
The link points to my post which contains the link you need to follow. Being 3.5" makes no difference to isolating, except PCB needs to be removed to insert some paper or other material for isolating.
You only need to enter in Kernel mode to block access, so isolating, shorting or using jumpers should all allow work via Kernel mode.
Posted: 13.02.18, 17:54
by murphman
Finally got it work with the jumpers (kernel) after messing around with the LDR (although didnt actually upload anything); was able to get and block SA access and manually fix slow responding through http://blog.acelab.eu.com/pc-3000-h ... rives.html
Problem solved, thanks!
Posted: 14.02.18, 10:35
As a sidenote, this process you followed cannot be executed on more modern models such as TrailsXLS as there is a direct correlation between the relocation process and the active translation system so clearing 02 module will cause 'shifts' in the data and many files will be corrupted.
Posted: 25.02.18, 09:15
by Amarbir[CDR-Labs]
AJ2008 wrote:Source of the post As a sidenote, this process you followed cannot be executed on more modern models such as TrailsXLS as there is a direct correlation between the relocation process and the active translation system so clearing 02 module will cause 'shifts' in the data and many files will be corrupted.
Senior Sahib ,
How do you solve issues in these modern drives
