WD10SPZX SED protection
Posted: 21.01.18, 09:21
by DCDL
is it possible to get around SED lock on Western Digital WD10SPZX-24Z10T0?I have tried to fallow SED lock solution from support blog but all i get is: in normal mode "unable to autodetect" and in kernel mode "SED drive locked"...
Re: WD10SPZX SED protection
Posted: 05.02.18, 19:28
by Miodrag
Did you block service area (as is described in the blog) and load DIR and loader into RAM, after that, you can reload hdd and Edit HDD ID (remove SED checkbox)...
Posted: 06.02.18, 08:34
by Maxim_TS
DCDL, maybe some head can not write. try to do the SED unlock in RAM: http://blog.acelab.eu.com/pc-3000-f ... n-ram.html
If it doesn't work, contact us in support: ts.acelab.eu.com
Posted: 27.10.18, 17:54
by HardExpert
WD10SPZX is Palmer family . PC3000-UDMA not support this family . because Palmer, SpyGlass and Charger are a high-encrypted families from WD .
Posted: 31.10.18, 17:40
by Amarbir[CDR-Labs]
HardExpert wrote:Source of the post WD10SPZX is Palmer family . PC3000-UDMA not support this family . because Palmer, SpyGlass and Charger are a high-encrypted families from WD .
I can do a lot of work with Palmer , Spyglass , Peppleb , And Charger Family .
Posted: 22.12.18, 16:31
by betty
hello ,
i have the drive WD20SDZW WITH SED PROTECTION error; logs giving below;
tb WD USB hdd i convert it to SATa and now it conecte via sata connection . at present it giving following error with Capacity 0ROM:
Read ROM................................ : HDDs ROM reading error Data request error Device Error Detected: "SED DRIVE LOCKED"
Service area:
SA dir reading (ID)..................... : SED DRIVE LOCKED
SA dir reading (ABA/CHS)................ : Dir reading error ABA 0(1) reading error Device Error Detected: "SED DRIVE LOCKED"
Configuration reading................... : Module ID 02 reading error Data request error Device Error Detected: "SED DRIVE LOCKED"
Module ID 0B reading error Data request error Device Error Detected: "SED DRIVE LOCKED"
Block module 02 access
Module ID 00 reading error Data request error Device Error Detected: "SED DRIVE LOCKED"
also drive doesn't detect its family itself
1.Is this drive is support in pc3000 ?
2. if yes, which family should select ?
I attach the pics of the hdd
Betty
image 2.png (36.92 KiB) Viewed 15491 times
Posted: 22.12.18, 22:04
by shahi
Whats the pcb no?
Posted: 23.12.18, 00:36
by Doomer
betty wrote:Source of the post
This drive is not supported by PC3K
It's Charger family
I can recover it if you'd like to outsource
