WD3200BEVT-63ZCT0
MicheleVitiello
WD3200BEVT-63ZCT0
Postby MicheleVitiello » 31.03.17, 15:38
Hi all, I've encountered this drive and I think heads are not working.
I'm looking for a compatible HDD for a heads swap because I can't find a donor with same model.
HDD Info:
Model: WD3200BEVT-63ZCT0
Date: 15 September 2009
DCM: HHYT2HNB
PCB: 2061-701499-E00
Could you please suggest a compatible donor? :D
Re: WD3200BEVT-63ZCT0
Postby Amarbir[CDR-Labs] » 02.04.17, 08:30
MicheleVitiello wrote:Source of the post Hi all, I've encountered this drive and I think heads are not working.
HDD Info:
DCM: HHYT2HNB
any drive from same family ,thats the code after - of mdl number
Maxim_TS
Postby Maxim_TS » 04.04.17, 19:00
MicheleVitiello, If the drive was not dropped, you can try to initialize it using the head map changing in RAM: http://blog.acelab.eu.com/ram-head- ... -case.html
If both system heads can not work - then look for a donor.
