Compatible SATA PCB with 2060-771945 : TRAILXLS Family
Posted: 23.10.16, 11:07
by GuideRecovery
I hope someone can point a compatible SATA pcb for:
WD10EZRX-00L4HB0
PCB: 2060-771945
TRAILXLS Family
The problem is native pcb is missing and i could't find said PCB or drive.
Is there another PCB which is compatible with this one ??
thanks in advance.
Re: Compatible SATA PCB with 2060-771945 : TRAILXLS Family
Posted: 24.10.16, 21:39
by DataMedics
Problem with that family is it doesn't have the ROM stored in the SA like some others do. You'll be very lucky if you can find a compatible ROM code for it.
Best bet is to tell your customer to do everything and anything to track down the original ROM. Otherwise you'll have to resort to trying every ROM you can get your hands on and hope to eventually find one that's close enough to work.
Posted: 25.10.16, 11:43
by GuideRecovery
thanks for reply,
so there is another problem of ROM as well.
do you know of any PCB which i can use against it ??
lets see, will talk with customer
regards
Posted: 25.10.16, 16:09
by DataMedics
There's 20 of these on ebay:
http://www.ebay.com/sch/i.html?_from=R4 ... 5&_sacat=0However, I think you'd be better off trying to find the closest matched drives you can and hope to get one with a close enough ROM code to work. If you can find one nearly identical built the same week or two, it might work.
