WD10EARS 00Y5B1 - HDDs RAM reading error
Posted: 06.09.16, 14:41
by rogaland
I have a WD10EARS 00Y5B1 that autodetects as DragFly2 family. (Is this correct?)
Starting in Normal mode I get this output:
Code: Select all
Techno mode key
RAM:
Cyl Count............................... : 192
Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ROM:
Modules directory address............... : 281 795
ROM Modules:
ROM version............................. : 15.1RF
ROM F/W version......................... : 0015001R
Overlay F/W version..................... : 15.1RF
Servo F/W version....................... : 04.0G
Service area:
SA dir reading (ID)..................... : Drive is not ready
SA SPT Detect........................... : FAIL
SA dir reading (ABA/CHS)................ : Module reading error: ABA 660 803(1) reading error Physical read error C/H/S: 371/1/296 Device Error Detected: "VSC ERR KEY SECTOR MUST PRECEED DATA XFER REQUEST"
What is the suggested steps from here?
Re: WD10EARS 00Y5B1 - HDDs RAM reading error
Posted: 06.09.16, 19:30
by DataMedics
Well, I see it's failing to read the SPT (aerial density) which usually indicates a head failure. Try editing the head map in RAM to 0 0 0 0 and/or 1 1 1 1 then perform a soft reset and see if you can read the SA SPT then. Could be just one bad head, or could be all of them.
Posted: 07.09.16, 18:50
by Maxim_TS
Thanks to DataMedics for a good advice. I just would like to remind that some drive families require the loader in RAM for head map editing.
Also tell us: Is the disc rotates? Is it rotates with blocked SA access in ROM?
If it's not, most possibly the heads are really bad.
Posted: 08.09.16, 08:59
by rogaland
The disk starts spinning up, there is a clicking sound as it tries to read data, and then it spins down.
When I select "RAM Head map editing" I get the following errors:
Code: Select all
Code type to check...................... : TypeN
Code addr............................... : FFE00000
Code size............................... : 327680
Code reading............................ : RAM Range FFE00000 (050000) reading error Device Error Detected: "VSC ERR KEY SECTOR MUST PRECEED DATA XFER REQUEST"
No HDD RAM access, LDR upload is recomended
Code type to check...................... : Type1
Code addr............................... : 1081A800
Code reading............................ : RAM Range 1081A800 (050000) reading error; unexpected error:  -; unexpected error: Operation aborted
I really appreciate you guys taking your time to "talk me through" this!
Posted: 08.09.16, 15:22
by Maxim_TS
rogaland, load the loader into RAM using Work with RAM->LDR file loading. Use the resources from same ROM FW version donor. Look for resources here: http://files.hddguru.com/download/PC-30 ... 20utility/
Then go to Work with RAM->RAM head map changing. Here is some kind of manual: http://blog.acelab.eu.com/ram-head- ... -case.html
Posted: 09.09.16, 08:26
by rogaland
Thank you very much Maxim. (I'm still waiting to get on a basic PC-3000 training course so I need some hand-holding)
According to PC-3000 my HD has ROM version 0015001R. Not sure if any of the files at http://files.hddguru.com/download/PC-3000-UDMA%20Support/WDC%20Marvell%20family%20utility/DragFly2/ will do the trick? I notice that the only 15001R match I get is from a WD10EARS-67Y5B1, but maybe the loader is the same?
Posted: 09.09.16, 11:58
by Maxim_TS
rogaland, these resources will give you a loader 0015001R: http://files.hddguru.com/download/PC-30 ... 831179.rar
Posted: 09.09.16, 13:07
by rogaland
Maxim_TS wrote:Source of the post rogaland, these resources will give you a loader 0015001R: http://files.hddguru.com/download/PC-30 ... 831179.rar
Should I go with "Write overlay in ram"?
After editing the head map, how do I then test if I can read SA? Using SA Structure test for example?
Posted: 13.09.16, 19:33
by Maxim_TS
rogaland, load the loader files, and then follow this manual to edit the head map: http://blog.acelab.eu.com/ram-head- ... -case.html
