Yes, thank you for sharing this information.Hary wrote:Source of the post All WD 2,5" USB drives (not slim)that has pins on PCB in two raws including this one from topic can be connected using Toshiba adapter as on attached picture
and this new L or as You wish J shape PCB can be connected via soldering 3 cable
Boot ROM Mode - Schematics For 2.5" SATA Interface
Re: Boot ROM Mode - Schematics For 2.5" SATA Interface
- Amarbir[CDR-Labs]
Well ,
i got the adapter only now but i still use toshiba adapter,The WD 2.5" adapter helps well in recovery of dead pcb in 2.5" using boot mode
Friends, I've added the new WD USB manual in update boxes, there are some new pictures for adapter connections and terminal connection presented.
heres a really easy way to connect serial port
solder two pins
and connect ribbon cable direct
viewtopic.php?f=155&t=7397&start=30
[urlhttp://forum.acelaboratory.com/download/file.php?id=842&mode=view][/url]
solder two pins
skype: wayne_horner
Alandata Data Recovery
Very cool Wayne! Thanks for sharing!
