WD20SDRW-11VUUS0 Orginal pcb,cpu is damaged data importent
Posted: 22.12.25, 15:26
The drive experienced a short-circuit on its PCB, which subsequently damaged the CPU. Fortunately, the ROM remains intact, and prior to the CPU failure, I was able to retrieve some modules from the drive.
I transferred the original ROM to a donor PCB and powered on the drive. It is now being recognized, and PC-3000 displays all the hard drive information correctly. However, the data appears to be encrypted. I attempted to decrypt it using PC-3000, but the software could not locate the encryption key.
To address this, I wrote some modules back to the drive. After doing so, PC-3000 was able to detect the encryption key, yet the data remains encrypted. I also tried disabling the Self-Encrypting Drive (SED) option in the "Edit HDD ID" settings, but this did not resolve the issue.
Drive had PCB 2060-800067
Could you please provide guidance on how to proceed? Recovering this data is extremely important to me.
Thank you for your time and assistance.
Best regards,
tarasheh
Best regards,
tarasheh
