WDC WD20SDRW-11VUUS1 formatted, t2 restore
Posted: 29.10.25, 08:26
my customer did a format of this hard drive,
The t2 analysis gives me:
Reading method.......................... : VSC command (T2 Data read)
Translator data reading................. : Ok
Translator data decode.................. : Ok
BAD node count.......................... : 0
Root node............................... : Correct
Node state set.......................... : Ok
Intersection check...................... : Completed
Lost LBA area........................... : NONE
Wrong entry nodes....................... : NONE
Zero areas check........................ : Completed
Zero LBA area count..................... : 8 (99,991%)
T2 analysis............................. : Completed
So what I see is the newly created ntfs partition, the rest is zeroed out, hidden by the translator.
I'm also able to read the SED key, but this doesn't help me, because I think it's only the current key.
If I disable sed, I can't decrypt any data, also not with the read key.
Is there any way to restore data on this sed drive?
