WD10JPVX Still got BSY after Slow Responding Fix
Posted: 25.03.25, 17:34
by gameboybin
Hi everyone. I have a drive that came in knocking. I have changed the heads and the drive comes in RDY however when got BSY when ID
I then proceeded to do Slow Responding Fix. Which did Upload LDR and module 02 normally. I backed up All SA modules. And tested which all gave green
However as soon as i Allow SA access and restart the drive. The drive hangs on BSY upon ID again
Can anyone help me out with this issue?? Many Thanks!!!
Model : WDC WD10JPVX-75JC3T0
Serial : WXC1A5739JJL
Firmware : 03.01A03
Capacity : 0 MB (1)
Code: Select all
Family:................................. : FBLite 2.5"
System controller (SoC)................. : 88i9446C0 0x(A5C0)
Modules directory address............... : 157 871
SA regions address...................... : shifted
SA SPT.................................. : 0
ROM Modules:
ROM version............................. : 16.94G
Module 4F F/W version................... : 00160094
Overlay F/W version..................... : 16.94G
Servo F/W version....................... : NA.41
Power up load dir data.................. : No
Power up load permovl................... : No
Power up load CFG data.................. : No
 NN | Step |    Time | Flags |     Info | Description
 16 |  405 | 16.24 s |    3F | 51045499 | ACTUATOR_INIT(Unknown error code: 5499)
 18 |  414 | 16.24 s |    3F | 51045499 | SPIN_DOWN_DONE(Unknown error code: 5499)
 22 |  414 | 16.24 s |    3F | 51045499 | SPIN_DOWN_DONE(Unknown error code: 5499)
DCM in module 47........................ : AY
DCM in module 0A........................ : |Q|2AYX1HS
ROM Backup.............................. : <HDD Profile>\Data\SAAutoBackup\ROM\ROM-2025-03-25-23-37-43.bin
HDD SA blocking......................... : Ok
Drive power supply...................... : OFF
Drive power supply...................... : ON
Resources folder........................ : C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\WDCMarvell\FBLite\16-94G-WDC ROM MODEL-FBLITE--03-01A03-WXC1A5739JJL\Data\Modules\Composed
Permanent ovl (11) data uploading....... : Ok
Module 02 uploading..................... : Ok
SA SPT.................................. : 1437
ROM Modules:
Overlay F/W version..................... : 16.95G
 19 |  105 | 12.31 s |    3F | 5104370F | EXEC_POWERUP_LOAD_DIR_DATA(FM ERR HEADER II SIGNATURE INVALID)
 46 |  105 | 12.68 s |   13F | 5104370F | EXEC_POWERUP_LOAD_DIR_DATA(FM ERR HEADER II SIGNATURE INVALID)
Service area:
Dir items loaded........................ : 505
SA Access............................... : Copy 0,Copy 1,Copy 2,Copy 3
Self encryption drive................... : No
DCM in module 02........................ : S|BQL|P2MAHYCXR1VHKBUK
Screenshot 2025-03-25 234223.png (70.33 KiB) Viewed 3421 times
Re: WD10JPVX Still got BSY after Slow Responding Fix
Posted: 26.03.25, 06:58
by digitalsupport
Don“t allow SA access, upload Dir+LDR, any other mods you do in RAM and then get the data.
0 MB Capacity could hint at other issues also.
Update: I see you posted more details over on guru forum, +1 for pepes suggestion to check dir.
Posted: 26.03.25, 17:36
When regions blocked and LDR and DIR uploaded to ram, if you send soft reset does it hang on BSY again?
Also, when regions blocked and after LDR and DIR uploaded try RAM head map to '0,0,0,0' then soft reset to check once again if BSY flag comes on
If after any resets BSY goes and DSC DRD remain can you refresh ID?
Posted: 31.03.25, 16:49
by gameboybin
So after all it was still the heads. The platters possibly have too much degradation that killed that new set of heads. I changed the heads 1 more time. And got like half of the drive mapped
Posted: 31.03.25, 16:52
by gameboybin
AJ2008 wrote:Source of the post When regions blocked and LDR and DIR uploaded to ram, if you send soft reset does it hang on BSY again?
When regions blocked and LDR and DIR uploaded to ram, if you send soft reset does it hang on BSY again? - No it still got DRD normally
Also, when regions blocked and after LDR and DIR uploaded try RAM head map to '0,0,0,0' then soft reset to check once again if BSY flag comes on - Yes the BSY comes on
If after any resets BSY goes and DSC DRD remain can you refresh ID? - yes i can
