ROM for seagate ST4000nm0035
Posted: 30.10.24, 06:43
by roham
hello guys
I have a patient seagate hard drive st4000nm0035 with board number 100760706. The registers do not turn on and the spindle does not turn. I got a donor board and put it on the patient's hard drive without writing the patient's ROM. The spindle spun with a screeching sound and the BSY register lit up.
Then I write the patient ROM on the donor board, to my surprise, the spindle did not spin again and the BSY, DRD, DWF, DRQ, CRP registers are pale green.
Can anyone guide me?
by regards
Re: ROM for seagate ST4000nm0035
Posted: 30.10.24, 16:36
by d_d_recovery
Best to open it in the cleanroom first and take a look inside. You might be wasting your time with the ROM.
Posted: 02.11.24, 06:38
by roham
hi dear
I also thought it is Headpark. But it wasn't.
Why doesn't the spindle spin with its original ROM, but it spins with the native ROM ST6000nm0115?
When I write the patient rom on the donor, the spindle still does not spin. :-| :-|
Re: ROM for seagate ST4000nm0035  Topic is solved
Posted: 02.11.24, 17:55
by d_d_recovery
roham wrote:Source of the post hi dear
Sound like the patient ROM is corrupt. Post a copy here.
Posted: 05.11.24, 06:32
by roham
Thank you for your time.
ROM is attached
ROM.rar
(331.88 KiB) Downloaded 170 times
Posted: 11.11.24, 06:43
by roham
d_d_recovery wrote:Source of the post
my friend
Do you know the terms of PCB swap? Do the two hard drives have to be exactly the same, or is it enough to have the same PCB number?
