WD5000AAKX-60U6AA0 Click twice then spins down
Postby gameboybin » 18.09.24, 09:42
I got a drive 500GB WD. That from the beginning was clicking twice then spins down. Upon inspection the PCB, the ROM everything seems fine. So i came to conclusions that it is the heads
Got a matching donor, checked the platters and swapped heads. The drive still Clicked twice then spins down
I have tried uploading LDR, tried hot swapping but nothing worked.
Can anyone help me out?? Any suggestions is welcomed??
Thanks everyone!
Code: Select all
Family:................................. : Tahoe XL
System controller (SoC)................. : 88i9045B0 0x(63B0)
Modules directory address............... : 82 104
SA SPT.................................. : 1290
ROM Modules:
ROM version............................. : 05.30G
Module 4F F/W version................... : 00050030
Overlay F/W version..................... : 05.30G
Servo F/W version....................... : 0A.22
Read ROM DCM............................ : Ok
Power up load dir data.................. : No
Power up load permovl................... : No
Power up load CFG data.................. : No
NN | Step |     Time |    Flags | Info | Description
12 | 710A |    12 ms |      501 | 2093 | SET_SOC_POWER_MODE(Unknown error code: 2093)
15 |  405 | 5 575 ms | 2000083A | 5443 | ACTUATOR_INIT(SERVO ERROR CODE BASE SvirActPdFail)
20 | 710A | 5 575 ms |      501 | 2093 | SET_SOC_POWER_MODE(Unknown error code: 2093)
28 |  419 | 5 576 ms | 2000083A | 5480 | CAL_RRO_USER_ZONE(SERVO ERROR CODE BASE SvirCalRRO Hd0)
Service area:
SA dir reading (ID)..................... : Module ID 01 reading error Device Error Detected: "DISK SERVO ACTUATOR AI FATAL ERROR"
SA dir reading (ABA/CHS)................ : Module 01 reading error: ABA 82 104 C:1(1) reading error Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
Configuration reading................... : Module ID 02 reading error Device Error Detected: "FM ERR NOT FOUND IN DIR"
DCM in module 47........................ : N5
DCM in module 0A........................ : |B|DN5SDAS
DCM in module 02........................ :
