SpyGlass2 Ultra (MCU encrypt) - problem after partition format...
Posted: 24.04.24, 15:24
Hello everyone,
HDD USB - WD40NDZW-11A8JS0 (SpyGlass2 Ultra) after formatting the partition.
User area is empty (almost same 0)
I have the original USB PCB converted by soldering the SATA connector. ROM unlocked.
The disk is physically full functional - all SA modules are saved without errors.
After conversion to SATA, the empty partition is visible just like on USB.
Because it is SpyGlass2 Ultra (encrypt by MCU), the data are encrypted using T2.
So PBA mode is out of the question - just try LBA.
Without the second translator (in PBA mode) can't finds any signatures.
Does anyone have an idea how to get to the data after formatting partition in this case (MCU encrypt) ?
I know that in the last update (PC-3000 ver. 7.4.x, ver. 6.4.x) AceLab added this option (after formatting).
Unfortunately, I have a version from a year and a half ago (PC-3000 ver. 7.2.12, DE ver. 6.2.11) and I cannot afford to upgrade at the moment.
Is it possible to do it another way?
Thank you in advance for any information.
Also from anyone who has encountered such a problem.
Igen
Igen
