WD NAND Cache memory
Posted: 20.02.24, 05:32
Hello Everyone,
I have a WD3003FZEX-00Z4SA0 with a badly burned PCB. I'm attempting to use a donor PCB with the original ROM, but it appears that the NAND memory from the donor drive PCB is preventing the drive from becoming ready.
Is there a way to disable the PCB NAND Cache memory through ROM manipulation? I've attached the original ROM.
Thank You
Thank You
- ROM.zip
- (513.68 KiB) Downloaded 197 times
