WD2003FYYS
Posted: 18.02.23, 19:54
Hello all, I have a 2TB WD here that a TA helped me with. I have to change back SA regions address since its shifted. NO Dir in HDD Ram, a module 02 error with LDR uploaded recommended. I'm still new to this but thought I would post to see if anyone can walk me through it. Thank you.
At first the drive was stuck in BSY state with no device ID. Changed heads with working donor and drive becomes ready.
Techno mode key
System controller (SoC)................. : 88i9045B0 0x(63B0)
Modules directory address............... : 320 647
SA regions address...................... : shifted
SA SPT.................................. : 1945
ROM Modules:
ROM version............................. : 05.0QF
ROM F/W version......................... : 0005001M
Overlay F/W version..................... : 05.0QF
Servo F/W version....................... : 02.02
Service area:
Dir data................................ : No
Permanent overlay....................... : No
CFG data................................ : No
Dir items loaded........................ : 463
No dir in HDD RAM found. To get access by ID to SA modules please uploadg dir to RAM
Configuration reading................... : Module 02 reading error: ABA 320 671 C:1(1) reading error Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
Drive power supply...................... : OFF
Techno mode key
ROM Modules:
Service area:
