WD160EDGZ-11B2DA0
Posted: 13.01.23, 23:23
Good day,
We have a 16TB WD (See attached) This is a newer 2021 model (which I believe is not supported by PC-3000 as of now). The head is stuck. I do not see a clear way of opening this one. The top and bottom have "covers" which are just adhered and easy to remove, but once you do that there is no easy way that I can see to open this. Has anyone had experience in opening this hard drive properly?
Any help will be appreciated.
Thank you
Thank you
