Unable to unlock SED HDD : ROM section code not found.
sbmtl
Postby sbmtl » 04.08.22, 19:14
Hi everybody
I tried SED unlock new option of PC3K but it doesn't work.
I have this ERROR message after reading locked ROM with Neo Programmer and CH341A USB module as described in Acelab video https://www.youtube.com/watch?v=znNgJkqJYrw :
ROM section code not found. This ROM is probably already unlocked!
But no it's still SED locked.
This is a WD 6tB wd60ezrz
1/ Did I make a mistake when I use Neo Programmer to save the ROM?
2/ Is this drive supported for unlocking SED process or I have to wait for next update of PC3K software?
Imre
Ancien rédacteur en chef de nombreux magazines informatiques (Amiga notamment),
Français d'origine hongroise, russe, tchèque et allemande, immigré au Canada (Montréal) depuis une douzaine d'année.
datasalvage
Re: Unable to unlock SED HDD : ROM section code not found.
Postby datasalvage » 03.10.22, 05:11
same situation here! dont knopw why! i have the latest version of pc-3000 software installed!
jojo2012
Postby jojo2012 » 09.11.22, 15:43
Same problem with WD30EZRZ-00GXCB0, PCB: 800055
MrHopper
Postby MrHopper » 27.10.25, 16:22
same here with:
WD30EZRZ-00Z5HB0 PCB:2060-771945
but this procedure works for unlocking:
https://blog.acelab.eu.com/pc-3000-for- ... n-ram.html
italyassistance
Postby italyassistance » 29.10.25, 17:47
probably rom it was read badly.
Postby AJ2008 » 31.12.25, 14:37
jojo2012 wrote:Source of the post Same problem with WD30EZRZ-00GXCB0, PCB: 800055
This is not locked ROM, but SED active in module 02
Without SED active likely data will be encrypted but can remove for SA repairs etc
