WDC WD20EARS-00MVWB0 drive show RAW in explorer
Posted: 09.03.22, 01:37
by efx
Need some help. I have taken basic training but I couldn't understand the process. Drive show as RAW in windows.
Model : WDC WD20EARS-00MVWB0
Serial : WD-WCAZA8385931
Firmware : 51.0AB51
Capacity : 2 TB (3 907 029 168)
ROM F/W version......................... : 00200076
FlDir:.................................. : 20B
Phys - SA C:............................ : 256 (192)
UA:..................................... : 259 101
H:...................................... : 6/6
S:...................................... : 1 980
Family:................................. : Sadle G6
Src..................................... : ATA0
Arh:.................................... : Marvell ROYL 20B
Mode:................................... : Normal
Err:.................................... : 51A2
Techno mode key
RAM:
SA SPT.................................. : 1980
ROM:
Modules directory address............... : 377 647
ROM Modules:
ROM version............................. : 20.76E
Overlay F/W version..................... : 20.77E
Servo F/W version....................... : 0B.3B
Heads map............................... : 0,1,2,5,6,7
Service area:
Dir data................................ : Yes
Permanent overlay....................... : Yes
CFG data................................ : Yes
CFG tech mode lock...................... : No
Self encryption drive................... : No
wd20ears-00mvwb0.log
(41.62 KiB) Downloaded 446 times
Re: WDC WD20EARS-00MVWB0 drive show RAW in explorer
Posted: 09.03.22, 15:08
by d_d_recovery
You do have some media damage and/or some head failure - "DISK ECU UNSAFE ERROR".
Have you checked if the drive is encrypted if its from a WD MyBook?
DE > Command to read tab > Decryption at the bottom > Check that box.
If it find the key select it.
THEN, clear the map of all the previously read sectors.
And try to read the drive again.
Posted: 10.03.22, 21:11
by efx
Hi, I tried decrypt but it do not come up with Key. Auto detect say something modeuls already read windows disappears too fast.
