WD10JPVX-22JC3T0 Problem with Module 01 and 02
Posted: 02.03.22, 17:50
I have Patient WD10JPVX-22JC3T0 DCM: EHKT2HK patient have problem with module 01 and 02. Can someone help me with this case ? Thanks
Techno mode key
Modules directory address............... : 105 437
SA SPT.................................. : 1480
ROM Modules:
ROM version............................. : 16.0TH
ROM F/W version......................... : 0016000T
Overlay F/W version..................... : 16.0TH
Servo F/W version....................... : N0.18
Service area:
Dir data................................ : No
Permanent overlay....................... : No
CFG data................................ : No
SA dir reading (ID)..................... : Module ID 01 reading error: HDD Redynes timeout (10000)
SA dir reading (ABA/CHS)................ : Module 01 reading error: ABA 105 437 C:1(1) reading error Device Error Detected: "VSC ERR UNSUP ACTION CODE"
Configuration reading................... : Module ID 02 reading error Device Error Detected: "FM ERR NOT FOUND IN DIR"
Techno mode key
ROM Modules:
Service area:
