Looking for BOOT-ROM for WD20SMZW-11YFCSO FW: 0003001J
Posted: 29.10.21, 16:26
by Tobias Jungbauer
I hope someone can help me. I'm looking for a BOOT ROM for a charger drive with WD20SMZW-11YFCSO FW: 0003001J.
Original BOOT-ROM is damaged, it does contain a lot of FF, but it is possible to see what FW it is.
Does anybody have a 0003001J FW boot rom for this charger drive and is able to share? :-(
I do want to test if SA and hopefully also UA access is possible with it.
I wasnt able to find it on HDD guru.
best regards
Tobias
Re: Looking for BOOT-ROM for WD20SMZW-11YFCSO FW: 0003001J
Posted: 29.10.21, 16:35
by d_d_recovery
Tobias Jungbauer wrote:Source of the post I do want to test if SA or even better UA access is possible with it.
So you have both SA and UA access with the original ROM?
Posted: 29.10.21, 22:35
by Tobias Jungbauer
Hello!
No I do not, if so I would not need a donor BOOT ROM.
I was able to read original BOOT ROM partly with external reader.
Original BOOT ROM soldered on a donor PCB gives me no status registers at all.
I do want try to get access via a donor Boot ROM and hope that someone has a 0003001J in the database / as backup from an old task.
Posted: 29.10.21, 22:37
by Tobias Jungbauer
My original Boot ROM looks like this:
WD20SMZW_Patient.zip
(564 KiB) Downloaded 263 times
Posted: 29.10.21, 23:17
by d_d_recovery
Tobias Jungbauer wrote:Source of the post No I do not, if so I would not need a donor BOOT ROM.
You made it sound like you wanted 'better access' to UA ;-)
