Looking for BOOT-ROM for WD20SMZW-11YFCSO FW: 0003001J
Tobias Jungbauer
Postby Tobias Jungbauer » 29.10.21, 16:26
I hope someone can help me. I'm looking for a BOOT ROM for a charger drive with WD20SMZW-11YFCSO FW: 0003001J.
Original BOOT-ROM is damaged, it does contain a lot of FF, but it is possible to see what FW it is.
Does anybody have a 0003001J FW boot rom for this charger drive and is able to share? :-(
I do want to test if SA and hopefully also UA access is possible with it.
I wasnt able to find it on HDD guru.
best regards
Tobias
d_d_recovery
Re: Looking for BOOT-ROM for WD20SMZW-11YFCSO FW: 0003001J
Postby d_d_recovery » 29.10.21, 16:35
Tobias Jungbauer wrote:Source of the post I do want to test if SA or even better UA access is possible with it.
So you have both SA and UA access with the original ROM?
Tobias Jungbauer
Postby Tobias Jungbauer » 29.10.21, 22:35
Hello!
No I do not, if so I would not need a donor BOOT ROM.
I was able to read original BOOT ROM partly with external reader.
Original BOOT ROM soldered on a donor PCB gives me no status registers at all.
I do want try to get access via a donor Boot ROM and hope that someone has a 0003001J in the database / as backup from an old task.
Tobias Jungbauer
Postby Tobias Jungbauer » 29.10.21, 22:37
My original Boot ROM looks like this:
WD20SMZW_Patient.zip
(564 KiB) Downloaded 263 times
d_d_recovery
Postby d_d_recovery » 29.10.21, 23:17
Tobias Jungbauer wrote:Source of the post No I do not, if so I would not need a donor BOOT ROM.
You made it sound like you wanted 'better access' to UA ;-)
