WD10JPVX-60JC3T0 mod 11 damage
Posted: 13.09.21, 02:05
by Nova
This drive power on and trying to calibrate then shutdown, i have replaced the head it has the same issue. Trying to fix slow response issue, i get Module ID 11 reading error. Any idea guys?
Thank you
Re: WD10JPVX-60JC3T0 mod 11 damage
Posted: 13.09.21, 17:51
by Maxim_TS
Nova, try to block SA access in ROM and restart the drive. If it spins down again, the new heads are not compatible or platters have issues. Also check if PCB is good, try to use a donor PCB.
Posted: 14.09.21, 02:06
by Nova
Hi Max
I have tried blocking SA, restarts the drive no spin down, drive into kernel mode, upload dir into HDD RAM but failed, Module id reading error
Posted: 15.09.21, 12:10
Try to upload compatible donor loader
Posted: 11.11.24, 12:43
by protech
AJ2008 wrote:Source of the post Try to upload compatible donor loader
is anybody have compatible donor loader of FBLite WD10JPVX-60JC3T0, Please?
Posted: 11.11.24, 14:44
by digitalsupport
You need to tell us what version you are searching for..
Posted: 13.11.24, 06:46
by protech
digitalsupport wrote:Source of the post FBLite WD10JPVX-60JC3T0
Thank you for the help, the only thing I know is FBLite WD10JPVX-60JC3T0 this model how can I identify the version?
