PCB 2060-810035 to SATA
Posted: 20.05.21, 16:54
by pad-dataservice
Anyone got an idea of how to convert this one to SATA?
- PAD_20210520_165437.jpg (7.8 KiB) Viewed 19762 times
- PAD_20210520_165452.jpg (7.7 KiB) Viewed 19762 times
Re: PCB 2060-810035 to SATA
Posted: 24.05.21, 15:30
by pad-dataservice
Thanks - could you give a hit on the two capacitors that are usually removed when converting to SATA
Posted: 14.09.21, 20:55
by osity
Are you soldering a SATA connector to those points on the back, removing 4 capcitors and 1 crystal?
I did that, but my drive is SED.
Posted: 27.12.21, 11:49
by andrew55
Hello !
Please, tell me which of the points to which contact of the Sata connector leads?
