ROM REBUILD FOR PALMAR FAMILY
Posted: 03.03.21, 13:20
by techchef1
Dear Frds
I have recevied HDD WD10SPZX -08Z10T1 ,pcba Rom chip burnt and dead ,It is possible to recovery from rebuild from SA .. with unlock PCBA kindly share your idea
thnks
Re: ROM REBUILD FOR PALMAR FAMILY
Posted: 03.03.21, 16:58
by d_d_recovery
You should be able to use a donor ROM and Loader to access the SA.
Try to get as best match as you can in terms of SN and DOM if possible.
You may need to try several donors before you get SA access.
Posted: 04.05.21, 23:21
by Paradog84
Use donor Rom to gain SA access
Dump module 129 from SA, unpack this for ROM modules
Use module 109 for ROM base image, or the donor ROM you use for SA access
Posted: 28.08.22, 13:11
by mostafa1
can regenerate ROM from SA in PALMER , the pcb was burn????
