WD20EARX - head issue - can't edit the head map in RAM
Posted: 25.09.20, 12:48
I have case - WD20EARX-00PASB0. The owner had previously given it to an ordinary computer repair shop.
There they opened it without a clean room. They scratched the top plate and left fingerprints on it.
The heads looked like they had been torn from the ramp.
So far I have ignored the top surface condition. I swap the donor heads to see if it would ever start.
Unfortunately, it did not move. Heads clicking and spin off so I guess H5 fell.
I tried to edit the head map in RAM. However, LDR upload is needed for this.
When I try to load module 11 I get an error message.
5c is loaded correctly.
When I transferred the heads back to the donor, the donor doesn't start anymore either
What is problem?
Permanent ovl (11) data uploading Device Error Detected: "Unknown error. Error code: BFA0"
What is problem?
