WD5000BPVT-00HXZT1 - No SA access
Posted: 25.06.20, 15:45
I've got the above drive. Drive spins, clicks 11 times then becomes RDY.
Autodetect works, selects Zephyr utility in kernel mode. Utility starts but no HDD info is displayed.
I have several ROMs from HDDSurgery for this model, I have tried uploading each into RAM which gives me the XYZ HDD info. Restarting the utility in Normal mode then gives me the error 'Zone Allocation Table: HDDs RAM reading error Device Error Detected: "SCT INVALID FUNCTION CODE"'.
I also get the popup window for the HDD SA geometry parameters.
The ROMs I have seem to be a close match, any ideas what the issue could be, or are we looking at bad heads?
Thanks in advance.
Thanks in advance.
