WD6400AACS-00G8B1 Erreur
Posted: 31.12.19, 18:28
I consider myself to a newbie in recovery data. I use the PC3000 UDMA.
I got erros on this disk :
Quick test --> data access test --> Read sectors (0-1) error Device error detected "ABR"
SA structure test :
0002 : 0 : B : 164 593 : 3 : Yes : Error : Error : ADDEADDE/DFD9E0DE : : Configuration (HDD ID) (Pasport Sequrity Block)
0002 : 1 : B : 164 593 : 3 : Yes : Error : Error : ADDEADDE/DFD9E0DE : : Configuration (HDD ID) (Pasport Sequrity Block)
002E : 0 : Dr : 6 532 : 308 : Yes : Error : Ok : 58DAC5EE : : Loaded part of microprogram code
002E : 1 : Dr : 6 532 : 308 : Yes : Error : Ok : 58DAC5EE : : Loaded part of microprogram code
CONFIGURATION MODULE (02)
SA Copy num Location State
0 164 593 (3) CS,Header,Header acc
1 164 593 (3) CS,Header,Header acc
I dont know how i can go to further analysis or fix the problem.
Is there anybody who can help me please ?
Thanks in advance.
best regards
SA structure test :
Thanks in advance.
best regards
