WD7500BPVX Loader upload problem
Posted: 22.07.19, 16:04
Hi everybody
I'm faceing a new problem that I can't handle right now.
The drive is a WD7500BPVX-22JC3T0, It is clicking when I got it. I opened the drive to check platter, looks OK. It's a 3 head model, I found in stock a drive with the same model,fw,date between 2 months and dcm (TJ/TJ) and check it after open. Logical headmap is the same, but physically donor has 4 head. (As I know it's not problem.)
I swapped head and patient is spinning, no clicking sound and earn ready state but no ID. I try to block SA acces and upload loader, from the surface, from database, and from local backup also.
Drive can read dir, modul 2 and 1B from the surface but it's stuck at busy when try to upload 11(main ata overlay).
If I try to upload it from file/database I get time out error, or unexpected error.
The most annoying part is that the drive is spinning and I can hear that head is in the surface.
Without modul 11 I can't edit RAM headmap, or anything.
If somebody has any idea I would be gratefull if you share it with me.
Best regards David.
Best regards David.
