WDC WD30EZRZ-00WN9B0 - heads problem?
Posted: 04.05.19, 00:07
I have an interesting case.
During the start, the hdd make 2 clicks and the spindle stops.
The DRD, DSC and red ERR and ABR lights are on.
I suspected it was a problem of heads. So I tried to start the drive in a configuration with only one head turned on. Unfortunately, it did not help.
Then I tried to upload LDR.
And here it was successful. The disk started and get the correct ID.
Unfortunately, when copying the data, it turned out that there is a partial problem with reading from 2 heads.
The heads look like they have not read but there are areas where they read very nicely without any problems.
Could this be a logical problem?
