Page 1 of 2
PALMAR SLOW FIX
Posted: 23.04.19, 19:01
by shahi
Anyone worked with SLOW FIx issue in PalMar?
I've tried manual process, but drive ID is lost once tried.
PS # I've backed up all the fw before doing anything in SA
Re: PALMAR SLOW FIX
Posted: 24.04.19, 14:07
by lcoughey
I didn't think Palmer with SMR was supported with PC3000.
Re: PALMAR SLOW FIX
Posted: 24.04.19, 17:27
by shahi
lcoughey wrote:Source of the post I didn't think Palmer with SMR was supported with PC3000.
Once we use unlocked PCB, we can access fw.
Re: PALMAR SLOW FIX
Posted: 24.04.19, 17:35
by lcoughey
But, there still isn't a palmer utility, is there? To the best of my knowledge, none of the utilities are equipped to handle SMR SA and any attempt to write to SA could lead to the death of the drive.
Re: PALMAR SLOW FIX
Posted: 25.04.19, 11:03
Also, its not possible to recal CS on Palmer within PC3K to confirm changes - writing a 'empty' 32 module from a donor may help but this wont disable the relo collection process within module 02
I hear Palmer has support in the next release of PC3000 (and within current beta release) but I dont have it so I cant confirm...
Re: PALMAR SLOW FIX
Posted: 25.04.19, 18:25
by shahi
lcoughey wrote:Source of the post But, there still isn't a palmer utility, is there? To the best of my knowledge, none of the utilities are equipped to handle SMR SA and any attempt to write to SA could lead to the death of the drive.
No, there is no palmar utility, but we can access by pebbleb.
AJ2008 wrote:Source of the post Also, its not possible to recal CS on Palmer within PC3K to confirm changes - writing a 'empty' 32 module from a donor may help but this wont disable the relo collection process within module 02
I tried to edit manually the soecifuc area, but drive lost ID once did it. Rewrite originsl 02 gave access again.
Really? Its a good news about the new release. When is it coming? Any estimated date?
Re: PALMAR SLOW FIX
Posted: 25.04.19, 18:38
by lcoughey
shahi wrote:No, there is no palmar utility, but we can access by pebbleb.
I don't believe pebbleb is equipped to handle SMR.
Re: PALMAR SLOW FIX
Posted: 27.04.19, 14:22
by digitalsupport
There is a palmer utility now
Re: PALMAR SLOW FIX
Posted: 27.04.19, 15:57
by shahi
Yes...
I'm going to renew my TS, hopefully it gets working in my case...
Re: PALMAR SLOW FIX
Posted: 06.05.19, 14:34
by Bruno
anyone worked with the pc3k 6.6.29 and fix slowresponding Problem on an WD Palmer without buy unlocked PCB?
Re: PALMAR SLOW FIX
Posted: 06.05.19, 17:21
by pclab
I don't think it's possible..
Re: PALMAR SLOW FIX
Posted: 07.05.19, 12:57
by Bruno
Thank for the reply. I think also. So yesterday we ordered a unlocked PCB.
Re: PALMAR SLOW FIX
Posted: 07.05.19, 20:30
by shahi
The unlocked PCB helps but the version still doesnt help slow fix. Since it requires more work in palmar
Re: PALMAR SLOW FIX
Posted: 08.05.19, 20:45
by Maxim_TS
shahi, Indeed, Slow Responding Fix is not recommended to apply for SpyGlass and Palmer drives because of new 02 module structure.
ACELab developers are working on it.
But, the new version allows to get SA access, edit head map in RAM, build head map in DE, it's a very useful features, isn't it?
Re: PALMAR SLOW FIX
Posted: 09.05.19, 11:29
by lasek
But to get access to SA needed is unlocked PCB also with the last version PC-3000?
