New method of handling WD Caviar HDD Green, Blue and Black
Re: New method of handling WD Caviar HDD Green, Blue and Bla
Postby AJ2008 » 28.04.14, 14:32
UDMAbod wrote:Does this method work on clicking drives? I have a WD1600JS that clicks and shuts down, but becomes RDY.
DRDY status is reached from PCB only once Kernel mode is active.
If PCB is confirmed as good, you can try to adjust map of heads in RAM as next step
msurgeon
Postby msurgeon » 02.10.15, 17:17
Maybe I missed a step or two here: after selecting "Use Dir in utility" is it then necessary to "write Dir to HDD"? Should the drive ID properly after this procedure or do you have to set the SA regions editor back to its original settings and power off/on? It's been a while since I encountered this problem and I don't remember the whole procedure.
msurgeon
Postby msurgeon » 02.10.15, 19:04
Head 0 was bad. Made things more complicated.
Maxim_TS
Re: New method of handling WD Caviar HDD Green, Blue and Black
Postby Maxim_TS » 24.11.15, 13:13
minimalist, When you have fixed all necessary for data access modules, you need to restart the drive (power off\on), and reenter in Marvell utility to initialize the drive in PC-3000.
Then you go to Data Extractor and create a new task. Do not close the Marvell utility, it's necessary for head map building in Data Extractor.
superhik
Postby superhik » 21.01.16, 09:14
all attached pics are now garbage after moving forum
or am i only one having issue?
Greetz,
Nik.
Data Solutions Belgrade
nik@datasolutions.rs
http://www.datasolutions.rs
Maxim_TS
Postby Maxim_TS » 29.01.16, 13:57
superhik, The pictures are renewed, please enjoy :D
Postby Amarbir[CDR-Labs] » 25.02.16, 14:36
Maxim_TS wrote:Source of the post superhik, The pictures are renewed, please enjoy :D
Maxim ,
Thanks For The Effort
Filipp_TS
Postby Filipp_TS » 15.03.16, 15:05
Just to open Data Extractor utility from the main PC-3000 window, and create a new task for your drive.
You can contact a Technical support department for assistance: http://ts.acelab.eu.com/
mcsnadeem
Postby mcsnadeem » 14.06.16, 02:09
Nice topic... Cheers to ACE lab team
mcsnadeem
Postby mcsnadeem » 14.06.16, 02:10
I am new ace product user. Any can help to image or clone Hdd to work further more on drive. We have pc3000 udma
Maxim_TS
Postby Maxim_TS » 14.06.16, 10:22
mcsnadeem, please read the manuals and ACE Blog: http://blog.acelab.eu.com/ to know as much as possible about HDD work and diagnostics.
If after manual and Blog reading you still have a questions, contact Technical Support Team at ts.acelab.eu.com
