Hi everybody
I tried SED unlock new option of PC3K but it doesn't work.
I have this ERROR message after reading locked ROM with Neo Programmer and CH341A USB module as described in Acelab video https://www.youtube.com/watch?v=znNgJkqJYrw :
ROM section code not found. This ROM is probably already unlocked!
But no it's still SED locked.
This is a WD 6tB wd60ezrz
1/ Did I make a mistake when I use Neo Programmer to save the ROM?
2/ Is this drive supported for unlocking SED process or I have to wait for next update of PC3K software?
Imre
Unable to unlock SED HDD : ROM section code not found.
Ancien rédacteur en chef de nombreux magazines informatiques (Amiga notamment),
Français d'origine hongroise, russe, tchèque et allemande, immigré au Canada (Montréal) depuis une douzaine d'année.
- datasalvage
Re: Unable to unlock SED HDD : ROM section code not found.
same situation here! dont knopw why! i have the latest version of pc-3000 software installed!
Same problem with WD30EZRZ-00GXCB0, PCB: 800055
same here with:
WD30EZRZ-00Z5HB0 PCB:2060-771945
but this procedure works for unlocking:
https://blog.acelab.eu.com/pc-3000-for- ... n-ram.html
- italyassistance
probably rom it was read badly.
jojo2012 wrote:Source of the post Same problem with WD30EZRZ-00GXCB0, PCB: 800055
This is not locked ROM, but SED active in module 02
Without SED active likely data will be encrypted but can remove for SA repairs etc
