challenge for hot-swap donor for WD5000LMVW-11VEDS6
DataRescueItalia
Postby DataRescueItalia » 17.02.25, 14:07
Hello to everyone,
I've bought many donors for creaing a hot-swap donor but none works.
If you win this challange I could buy you the working hot-swap donor.
Thanks to everyone.
Cheers
PS: case closed :(
Re: challenge for hot-swap donor for WD5000LMVW-11VEDS6
Postby AJ2008 » 20.02.25, 11:19
traditional Hot Swap method will not work on this as it is LITE series which uses additional adaptive information in 4F ROM module
DataRescueItalia
Postby DataRescueItalia » 20.02.25, 15:15
well, can I ask you which NON traditional Hot Swap method I could use?
Cheers
Postby AJ2008 » 20.02.25, 16:21
I am not sure if is possible in pc3000, need to load client 4F to RAM after hotswap and I am not aware of option to do this there. Check with Ace support if there is support for this there.
DataRescueItalia
Postby DataRescueItalia » 20.02.25, 18:13
Ace support confirm all that you have written.
thanks a lot
Users browsing this forum: SGdata and 1 guest
