WD40EZRZ-22Z5HB0 that is BSY and spins down
se134
Postby se134 » 09.02.24, 10:19
I have a WD40EZRZ-22Z5HB0 that is BSY and spins down.
I thought the head was bad so I ordered a donor HDD and replaced the head.
However, the BSY and spin down condition did not change.
So I am trying to do ROM BlockSA and LDR upload, but it doesn't work.
When I put the original head into the donor HDD and turn on the power, it becomes ready.
Is this not a problem with the head but with the SA?
Is there any solution?
osity
Re: WD40EZRZ-22Z5HB0 that is BSY and spins down
Postby osity » 17.02.24, 05:09
Sounds like you need to disassemble the drive and inspect the discs for damage.
Users browsing this forum: No registered users and 2 guests
