Charger Unlocked PCB encryption issues
Re: Charger Unlocked PCB encryption issues
Postby gameboybin » 12.12.23, 07:58
DCDL wrote:Source of the post We use these......
https://www.hddheadtools.com/product/hdd-usb-sata-wiring-pcb-pro/
A tad expensive, but you can also find them on aliexpress - enough, or build your own from scrap PCBs. That way PC3K can easily control the power if required and you don't need the extra mess of USB cables in the way.
One more small question. How do you guys solder the COM connection through this board?? Or you guys don't??
Postby digitalsupport » 12.12.23, 08:52
I don´t solder COM. Read, unlock and write ROM with external programmer and pogo adapter.
Postby gameboybin » 23.01.24, 09:38
Guys. Sorry. I still need your help guys
So i got the donor. Changed the heads. Unlock ROM vs PC3000, soldered SATA connection. The drives spinning but kept busy without any noise from the heads. I think the heads aren't compatible even though i chose the donor very carefully :oops: :oops: :oops:
I wanted to know the compatibility of these drives. What to look for when buying a donor. And what to look for when changing those heads
Thank You!!!
Here are the pictures of the Patient and the Donor
Postby digitalsupport » 23.01.24, 10:06
What happens when you block access to SA + upload dir and ldr to RAM ?
Postby gameboybin » 24.01.24, 03:26
digitalsupport wrote:Source of the post block access to SA
How do you block access to SA without the com port???
Postby gameboybin » 24.01.24, 08:14
gameboybin wrote:Source of the post
Sorry. Wrong question. So i blocked access in SA upload dir to RAM. Put the drive in Normal mode however all sectors in Sector Edit reads 00 00
Postby gameboybin » 24.01.24, 09:08
digitalsupport wrote:Source of the post What happens when you block access to SA + upload dir and ldr to RAM ?
Nevermind. I managed to make it work. The drive have a lot of Disk Dam Errors
Cannot build head map from this. The LBA=0 keeps getting stuck
Cannot map fill
