Looking for compatible SATA PCB for WD40NMZW...
Re: Looking for compatible SATA PCB for WD40NMZW...
Postby digitalsupport » 27.05.22, 20:57
You can remove caps or short crystal, both works fine.
It will cause strange errors if SATA to PC3000 is connected in parallel with USB bridge, thats why you need to remove caps or short crystal.
