Anyone got an idea of how to convert this one to SATA?
PCB 2060-810035 to SATA Topic is solved
Re: PCB 2060-810035 to SATA Topic is solved
Here you go.
- pad-dataservice
Thanks - could you give a hit on the two capacitors that are usually removed when converting to SATA
- pad-dataservice
Great thanks
Are you soldering a SATA connector to those points on the back, removing 4 capcitors and 1 crystal?
I did that, but my drive is SED.
Hello !
Please, tell me which of the points to which contact of the Sata connector leads?
