i've a bigger problem - SA on H0 destroyed, also some Areas on H1 - but all in all - good SA
drive can initialize from H1 - but the problem is, that Module 25 (the encrytion key) on H1 has wrong checksum - so wrong data.
but he thinks everything is fine - but can*t read data from it.
so i thought - i just move the module to another area - log says, yeah - everything fine written - but... rearead, wrong data inside. - tried on 7 different places, everytime the same.
when i reboot the area is not moved, and module position is in same as before, it does not depend if i try to do with Dir Editing, or move modules function..
any ideas?
Moving modules FBLite 2,5"
- c.vogl@solution.at
- d_d_recovery
- User
Re: Moving modules FBLite 2,5"
It sounds like your heads will not write to the drive.
Have you done a head swap yet?
yes, headswap is done (2 Times), and i can write modules - but i can't move it. (on H1 it's no problem, on H0 in some places)
read modules and decrypt from file / folder instead of SA
AceLab already tried alot - but it does not work like expected, drive is back at customer - don't want to pay some bucks
If Ace tried and could not solve it then I guess there were other issues with more than #25 module - also mod #25 is not module for SED key so its possible other key modules were bad
